주요 콘텐츠로 건너뛰기
Pillow Stuffing Replacement
필요한 것
  1. Pillow Stuffing Replacement, Stuffing: 1 단계, 이미지 1/1
    • Measure the length and width of the pillow to determine how much stuffing is needed.
    • A standard sleeping pillow is 20"x26", and will require 2 lbs of polyester fiber fill.
  2. Pillow Stuffing Replacement: 2 단계, 이미지 1/1
    • With the seam ripper, create a 4-6 inch opening in the pillow about 2 inches from the corner.
    • To use the seam ripper: cut one stitch at a time using the sharp end. The red tip should remain upwards.
  3. Pillow Stuffing Replacement: 3 단계, 이미지 1/2 Pillow Stuffing Replacement: 3 단계, 이미지 2/2
    • Remove the existing stuffing from the pillow.
  4. Pillow Stuffing Replacement: 4 단계, 이미지 1/3 Pillow Stuffing Replacement: 4 단계, 이미지 2/3 Pillow Stuffing Replacement: 4 단계, 이미지 3/3
    • Place a tennis ball-sized amount of new stuffing firmly into the 3 intact corners of the pillow.
    • This will help open up and stabilize the shell of the pillow to ensure even distribution of the stuffing.
    • Continue adding stuffing to the pillow to desired stiffness.
    • To ensure a smooth and regular shaped pillow, gently pull at the stuffing until it is fluffy before placing it into the pillow.
  5. Pillow Stuffing Replacement: 5 단계, 이미지 1/2 Pillow Stuffing Replacement: 5 단계, 이미지 2/2
    • Use the scissors to cut a length of thread approximately 24 inches long.
    • A dark thread is used here to maximize visibility. Typically, the thread would be matched with the color of the fabric.
    • Thread the needle and slide it to the center of the length of thread.
    • Triple knot the two loose ends together.
  6. Pillow Stuffing Replacement: 6 단계, 이미지 1/3 Pillow Stuffing Replacement: 6 단계, 이미지 2/3 Pillow Stuffing Replacement: 6 단계, 이미지 3/3
    • Start a ladder stitch from the inside of the pillow by pulling the thread through the folded seam, right behind the opening that you created.
    • Make a small stitch through side of the opening.
    • Make an identical stitch directly across from your first stitch, on the opposite side of the opening. Pull the thread taut to begin the new seam.
    • Repeat, alternating from one side to the other until you have reached the end of the opening.
    • Be sure to keep each new stitch on the folds of the original seam.
  7. Pillow Stuffing Replacement: 7 단계, 이미지 1/2 Pillow Stuffing Replacement: 7 단계, 이미지 2/2
    • To compete the ladder stitch and close the pillow, pierce the needle through both sides of the seam and slowly pull the thread through until a loop is created.
    • Feed the needle through the loop and pull the thread tight.
    • Repeat this once more to ensure that the pillow is closed tightly, and cut off any excess thread with the scissors.
결승점
Kylee Harman
회원 가입일: 01/28/18
195 평판
안내서 1개 작성함
댓글 한 개
Thanks for sharing. Informative post. Keep up the good work.
Hamptons Cushions
mitu seo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 12
30일 전: 48
전체 시간: 2,865
