소개
Use this guide to replace a used, nonfunctional, or a reduced capacity battery in a Pine64 PinePhone. Batteries naturally degrade over time, so use this guide after a few years of strenuous use to give an older phone new life.
Before beginning, make sure to power off the phone and disconnect from any external power source.
Use caution. If the battery emits an odor, liquid, or is swollen, this repair may be dangerous.
필요한 것
Using a fingernail, press into the bottom divot and remove the battery from the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
