주요 콘텐츠로 건너뛰기
Pioneer A1 XW-SMA1-K Antenna Replacement
필요한 것
  1. Pioneer A1 XW-SMA1-K Antenna Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Antenna Replacement: 2 단계, 이미지 1/2 Pioneer A1 XW-SMA1-K Antenna Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Antenna Replacement: 3 단계, 이미지 1/3 Pioneer A1 XW-SMA1-K Antenna Replacement: 3 단계, 이미지 2/3 Pioneer A1 XW-SMA1-K Antenna Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Antenna Replacement: 4 단계, 이미지 1/2 Pioneer A1 XW-SMA1-K Antenna Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Antenna Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the motherboard from the speaker.
  6. Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: 6 단계, 이미지 1/2 Pioneer A1 XW-SMA1-K Antenna Replacement, Antenna: 6 단계, 이미지 2/2
    • Flip over the back panel and pull the antenna up and out.
결론
Drew Dickenson
회원 가입일: 02/14/19
295 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 10
전체 시간: 530
