주요 콘텐츠로 건너뛰기
Pioneer A1 XW-SMA1-K Motherboard Replacement
필요한 것
  1. Pioneer A1 XW-SMA1-K Motherboard Replacement, Back Panel: 1 단계, 이미지 1/1
    • Use the spudger to remove the mesh front panel.
  2. Pioneer A1 XW-SMA1-K Motherboard Replacement: 2 단계, 이미지 1/2 Pioneer A1 XW-SMA1-K Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the thirteen 12 mm screws in the speaker frame.
    • Remove the speaker frame by pulling vertically upwards revealing the motherboard.
  3. Pioneer A1 XW-SMA1-K Motherboard Replacement: 3 단계, 이미지 1/3 Pioneer A1 XW-SMA1-K Motherboard Replacement: 3 단계, 이미지 2/3 Pioneer A1 XW-SMA1-K Motherboard Replacement: 3 단계, 이미지 3/3
    • Use a Phillips #1 screwdriver to remove the twelve 12 mm screws from the middle frame.
    • Remove the middle frame by pulling upward and vertically.
  4. Pioneer A1 XW-SMA1-K Motherboard Replacement: 4 단계, 이미지 1/2 Pioneer A1 XW-SMA1-K Motherboard Replacement: 4 단계, 이미지 2/2
    • Use the Phillips #1 screwdriver to remove the nine 12 mm screws from the motherboard.
    • Flip the motherboard over.
    • Remove the motherboard by detaching the antenna.
  5. Pioneer A1 XW-SMA1-K Motherboard Replacement, Motherboard: 5 단계, 이미지 1/1
    • Remove the motherboard from the speaker.
결론
다른 2명이 해당 안내서를 완성하였습니다.
john adewoye
회원 가입일: 02/14/19
109 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 6
30일 전: 9
전체 시간: 568
