주요 콘텐츠로 건너뛰기
Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement
필요한 것
  1. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement, Control Panel Circuit Board: 1 단계, 이미지 1개 중 1개
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 3 단계, 이미지 1개 중 1개
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 4 단계, 이미지 1개 중 1개
    • Unlatch the three plastic connectors on the top of the receiver that hold the front panel to the device casing.
  5. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 5 단계, 이미지 1개 중 1개
    • The connectors on the bottom of the device may be very stiff and could require the use of a plastic prying tool.
    • Carefully flip the device over and unlatch the three plastic connectors that hold the front panel to the bottom of the device casing.
  6. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 6 단계, 이미지 1개 중 1개
    • Grip and unplug the ribbon connector that connects the front circuit board to the device.
  7. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 7 단계, 이미지 1개 중 1개
    • Unscrew the three 1/4 Phillips head screws on the back of the front circuit board.
  8. Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 8 단계, 이미지 2개 중 1개 Pioneer Elite PRO-RO6U Control Panel Circuit Board Replacement: 8 단계, 이미지 2개 중 2개
    • Grip the circuit board and slide towards the front side of the plastic casing.
    • Lift upwards to remove the circuit board from the front panel.
결론
작성자
2다른 기여자 명과 함께
Cody Carter
회원 가입일: 01/30/18
1,049 평판
안내서 6개를 작성함
Baylor, Team S1-G5, Johnson Spring 2018 Baylor, Team S1-G5, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G5
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 4
전체 시간: 593
