주요 콘텐츠로 건너뛰기
Pioneer Elite PRO-RO6U Power Supply Board Replacement
필요한 것
  1. Pioneer Elite PRO-RO6U Power Supply Board Replacement, Power Supply Board: 1 단계, 이미지 1/1
    • Remove the two 6.4 mm Phillips screws on each side of the device's casing.
  2. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 2 단계, 이미지 1/1
    • Remove the three 6.5 mm Phillips screws on the back of the device casing.
  3. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 3 단계, 이미지 1/1
    • Grip the front panel in one hand and the back of the casing in the other. Pull the casing back, and slide it up and away from the inner box.
  4. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 4 단계, 이미지 1/1
    • Gently pull upward and unplug cables D4 and D5.
  5. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 5 단계, 이미지 1/1
    • Remove the two 7/16 inch Phillips screws to the left and right of the power supply port.
    • Remove three 5/16 inch Phillips screws from the corners of the board.
  6. Pioneer Elite PRO-RO6U Power Supply Board Replacement: 6 단계, 이미지 1/1
    • Remove the power supply board by pulling it toward the interior of the device then lifting.
결론
Cody Carter
회원 가입일: 01/30/18
1,049 평판
안내서 6개 작성하였습니다
Baylor, Team S1-G5, Johnson Spring 2018 Baylor, Team S1-G5, Johnson Spring 2018 회원
BU-JOHNSON-S18S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 577
