주요 콘텐츠로 건너뛰기
Pioneer Elite Smart Speaker F4 Fabric Casing
필요한 것
  1. Pioneer Elite Smart Speaker F4 Fabric Casing, Fabric Casing: 1 단계, 이미지 1/1
    • Flip the speaker upside down with the back panel of plugs pointed away from you.
  2. Pioneer Elite Smart Speaker F4 Fabric Casing: 2 단계, 이미지 1/2 Pioneer Elite Smart Speaker F4 Fabric Casing: 2 단계, 이미지 2/2
    • Use the metal spudger to pry off the rubber bottom cover. It will be glued onto the bottom of the speaker.
    • Work the rubber cover off by slowly going all the way around with the metal spudger, applying as much force as needed.
    • Since the cover is glued, a heat gun at low temperature or a hair dryer may be useful to speed up the process. However it is not required in this step.
  3. Pioneer Elite Smart Speaker F4 Fabric Casing: 3 단계, 이미지 1/1
    • Scrape most of the glue away to reveal the five flathead screws - four around the outside, and one in the middle.
  4. Pioneer Elite Smart Speaker F4 Fabric Casing: 4 단계, 이미지 1/1
    • Remove the five 6 mm screws with a Phillips #2 screwdriver.
  5. Pioneer Elite Smart Speaker F4 Fabric Casing: 5 단계, 이미지 1/1
    • Lift off the metal plate. It will be surprisingly heavy and it is approximately 1cm thick.
  6. Pioneer Elite Smart Speaker F4 Fabric Casing: 6 단계, 이미지 1/3 Pioneer Elite Smart Speaker F4 Fabric Casing: 6 단계, 이미지 2/3 Pioneer Elite Smart Speaker F4 Fabric Casing: 6 단계, 이미지 3/3
    • This step requires permanently damaging the casing of your device.
    • Turn the speaker counter-clockwise 90 degrees.
    • Use a knife to cut along the left seam all the way down the length of the device.
  7. Pioneer Elite Smart Speaker F4 Fabric Casing: 7 단계, 이미지 1/2 Pioneer Elite Smart Speaker F4 Fabric Casing: 7 단계, 이미지 2/2
    • The casing should be easily removed by prying and lifting it off.
    • If the casing gets caught on the back panel of plugs, use the metal spudger to lift the casing away from the panel, working all the way around. Pay special attention to the bottom, where it may be stuck with glue.
  8. Pioneer Elite Smart Speaker F4 Fabric Casing: 8 단계, 이미지 1/3 Pioneer Elite Smart Speaker F4 Fabric Casing: 8 단계, 이미지 2/3 Pioneer Elite Smart Speaker F4 Fabric Casing: 8 단계, 이미지 3/3
    • Flip device 180 degrees so the light ring/button panel is on top with the 'Elite' facing you.
    • Remove one 6 mm screw with a Phillips #2 screwdriver.
    • Spin the device so the opposite side is facing you.
    • Remove the two 6 mm screws with a Phillips #2 screwdriver.
  9. Pioneer Elite Smart Speaker F4 Fabric Casing: 9 단계, 이미지 1/2 Pioneer Elite Smart Speaker F4 Fabric Casing: 9 단계, 이미지 2/2
    • Carefully remove the top panel, light ring, button panel, and the corresponding board.
    • Do not pull too hard, as there is a strip of wiring connected to the part below that could tear if pulled too hard or too far away.
결론
Alden Glassey
회원 가입일: 04/19/18
498 평판
안내서 3개 작성하였습니다
Cal Poly, Team S1-G1, Zimmerman Spring 2020 Cal Poly, Team S1-G1, Zimmerman Spring 2020 회원
CPSU-ZIMMERMAN-S20S1G1
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 11
전체 시간: 256
