주요 콘텐츠로 건너뛰기
Pioneer FH-X730BS Auxiliary Inlet Replacement
필요한 것
  1. Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: 1 단계, 이미지 1/3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: 1 단계, 이미지 2/3 Pioneer FH-X730BS Auxiliary Inlet Replacement, Deck Buttons: 1 단계, 이미지 3/3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Auxiliary Inlet Replacement: 2 단계, 이미지 1/3 Pioneer FH-X730BS Auxiliary Inlet Replacement: 2 단계, 이미지 2/3 Pioneer FH-X730BS Auxiliary Inlet Replacement: 2 단계, 이미지 3/3
    • After removing the stereo face from the frame it should look similar to this.
    • Remove the seven 11.2mm Phillips #1 screws on the rear side of the stereo face.
  3. Pioneer FH-X730BS Auxiliary Inlet Replacement: 3 단계, 이미지 1/3 Pioneer FH-X730BS Auxiliary Inlet Replacement: 3 단계, 이미지 2/3 Pioneer FH-X730BS Auxiliary Inlet Replacement: 3 단계, 이미지 3/3
    • Remove the volume knob by pulling it towards you and pull the motherboard out of the face.
    • The audio buttons can now be taken out. You can flip the face downwards and tap the audio buttons.
    • You can now insert the replacement audio buttons into the face.
  4. Pioneer FH-X730BS Auxiliary Inlet Replacement, Auxiliary Inlet: 4 단계, 이미지 1/1
    • Here you are able to desolder the auxiliary ports from the circuit board and solder a replacement auxiliary port on.
    • The end of the soldering iron will be hot.
결론
Cody Pesta
회원 가입일: 09/17/18
688 평판
안내서 6개 작성하였습니다
Washington State, Team S2-G4, Hope Fall 2018 Washington State, Team S2-G4, Hope Fall 2018 회원
WSU-HOPE-F18S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 181
