주요 콘텐츠로 건너뛰기
Pioneer FH-X730BS Disk Drive Replacement
필요한 것
  1. Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: 1 단계, 이미지 1/3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: 1 단계, 이미지 2/3 Pioneer FH-X730BS Disk Drive Replacement, Disk Drive: 1 단계, 이미지 3/3
    • Apply pressure to the tabs on each side using the plastic opening tool.
    • You will need to pull the face away from the frame while unhooking the tabs.
  2. Pioneer FH-X730BS Disk Drive Replacement: 2 단계, 이미지 1/1
    • After removing the stereo face from the frame, it should look similar to this.
  3. Pioneer FH-X730BS Disk Drive Replacement: 3 단계, 이미지 1/1
    • Remove the ribbon wire from where it is being held in place. This can be done by applying force upwards.
  4. Pioneer FH-X730BS Disk Drive Replacement: 4 단계, 이미지 1/3 Pioneer FH-X730BS Disk Drive Replacement: 4 단계, 이미지 2/3 Pioneer FH-X730BS Disk Drive Replacement: 4 단계, 이미지 3/3
    • Unscrew the four 7.3 mm outer screws on the top to remove the top face from the rest of the frame.
  5. Pioneer FH-X730BS Disk Drive Replacement: 5 단계, 이미지 1/3 Pioneer FH-X730BS Disk Drive Replacement: 5 단계, 이미지 2/3 Pioneer FH-X730BS Disk Drive Replacement: 5 단계, 이미지 3/3
    • Unscrew the four inner screws that are 7.3 mm long using a Phillips #1 head screw driver to remove the disk drive from the top face plate.
    • Replace the old disk drive with a new one.
결론
Cody Pesta
회원 가입일: 09/17/18
688 평판
안내서 6개 작성하였습니다
Washington State, Team S2-G4, Hope Fall 2018 Washington State, Team S2-G4, Hope Fall 2018 회원
WSU-HOPE-F18S2G4
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 9
전체 시간: 334
