주요 콘텐츠로 건너뛰기
Pioneer MXT-X366BT Knob Replacement
필요한 것
  1. Pioneer MXT-X366BT Knob Replacement, Volume Knob: 1 단계, 이미지 1/1
    • Push the eject button to release the faceplate.
  2. Pioneer MXT-X366BT Knob Replacement: 2 단계, 이미지 1/2 Pioneer MXT-X366BT Knob Replacement: 2 단계, 이미지 2/2
    • Carefully separate the faceplate from the radio.
  3. Pioneer MXT-X366BT Knob Replacement: 3 단계, 이미지 1/1
    • Remove three 3mm Phillips-head screws with a Phillips #1 screwdriver.
  4. Pioneer MXT-X366BT Knob Replacement: 4 단계, 이미지 1/3 Pioneer MXT-X366BT Knob Replacement: 4 단계, 이미지 2/3 Pioneer MXT-X366BT Knob Replacement: 4 단계, 이미지 3/3
    • Remove the back of the face plate.
    • Separate the motherboard from the casing.
    • Handle the motherboard with care.
  5. Pioneer MXT-X366BT Knob Replacement: 5 단계, 이미지 1/2 Pioneer MXT-X366BT Knob Replacement: 5 단계, 이미지 2/2
    • Firmly pull the volume knob.
    • Carefully handle the motherboard to not break it.
    • Some force may be required to remove the knob.
    • Buttons are attached by a ring behind the volume knob.
결론
martin esquivel
회원 가입일: 03/22/18
323 평판
안내서 2개 작성하였습니다
Sam Houston State, Team S17-G7, Blackburne Spring 2018 Sam Houston State, Team S17-G7, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 376
