주요 콘텐츠로 건너뛰기
Pioneer MXT-X366BT Metal Case Replacement
필요한 것
  1. Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: 1 단계, 이미지 1/2 Pioneer MXT-X366BT Metal Case Replacement, Metal Casing: 1 단계, 이미지 2/2
    • Apply small amount of pressure inward with a plastic opening tool to release bottom clip.
    • Pry the top clip with the plastic opening tool to release it.
    • The head unit is symmetrical and has the same amount of clips on the other side.
  2. Pioneer MXT-X366BT Metal Case Replacement: 2 단계, 이미지 1/1
    • Remove the face plate holder.
  3. Pioneer MXT-X366BT Metal Case Replacement: 3 단계, 이미지 1/1
    • Remove the six 5mm Phillips-head screws with Philips #2 screwdriver.
  4. Pioneer MXT-X366BT Metal Case Replacement: 4 단계, 이미지 1/2 Pioneer MXT-X366BT Metal Case Replacement: 4 단계, 이미지 2/2
    • Remove the inner three 5mm Phillips head screws, with a Phillips #2 screwdriver, attached to the metal backing.
    • Remove the metal backing that is now free.
  5. Pioneer MXT-X366BT Metal Case Replacement: 5 단계, 이미지 1/1
    • Carefully slide the metal casing forward.
    • Metal piece standing is the rear of the head unit.
    • Edges are sharp.
  6. Pioneer MXT-X366BT Metal Case Replacement: 6 단계, 이미지 1/1
    • Lift the metal casing from the rear and pull it away.
    • Edges are sharp.
  7. Pioneer MXT-X366BT Metal Case Replacement: 7 단계, 이미지 1/1
    • The metal casing is now fully removed.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Blaine Kaiser
회원 가입일: 03/22/18
169 평판
안내서 1개 작성함
Sam Houston State, Team S17-G7, Blackburne Spring 2018 Sam Houston State, Team S17-G7, Blackburne Spring 2018 회원
SHSU-BLACKBURNE-S18S17G7
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 3
전체 시간: 302
