주요 콘텐츠로 건너뛰기
Pioneer R1 LCD Display Replacement
필요한 것
  1. Pioneer R1 LCD Display Replacement, LCD Display: 1 단계, 이미지 1/1
    • Insert your plastic spudger in the opening near the HDMI port.
    • Gently pry the back cover of the R1 from the the front by using the spudger along the edges.
    • Do not pull the back cover straight off the R1 as components of the speakers will be attached to both sides.
  2. Pioneer R1 LCD Display Replacement: 2 단계, 이미지 1/1
    • Lay the R1 flat like an open book.
    • This will prevent the speakers from becoming disconnected from the motherboard.
  3. Pioneer R1 LCD Display Replacement: 3 단계, 이미지 1/1
    • Remove the tape that is holding the motherboard to the display and covering the cable attachments.
    • Peel back just the end of this tape to free the front facing camera.
  4. Pioneer R1 LCD Display Replacement: 4 단계, 이미지 1/1
    • Remove the three 4 mm screws along the base of the motherboard with a Phillips #00 Screwdriver.
  5. Pioneer R1 LCD Display Replacement: 5 단계, 이미지 1/1
    • Disengage the two cable locks using your spudger or your finger nail.
    • Slide the cable free from the disengaged lock.
    • Do not pull across the cables as this may tear and permanently damage it.
  6. Pioneer R1 LCD Display Replacement: 6 단계, 이미지 1/2 Pioneer R1 LCD Display Replacement: 6 단계, 이미지 2/2
    • Insert your spudger between the LCD display and the touch screen.
    • Gently pry the LCD display from the the touchscreen by using the spudger along the edges.
    • Once disengaged, remove the LCD display from the touchscreen.
  7. Pioneer R1 LCD Display Replacement: 7 단계, 이미지 1/1
    • Slide a strong thin object, like a thin spudger, between the battery and the display.
    • Slide the object along the length of the battery to remove it from the display.
    • The adhesive holding the battery in place is strong and the battery is quite soft. Take care not to break open the battery.
  8. Pioneer R1 LCD Display Replacement: 8 단계, 이미지 1/1
    • Carefully pry off the component that is taped to the LCD display at the top of the R1.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Christopher Rosario
회원 가입일: 02/17/15
411 평판
안내서 4개 작성하였습니다
San Diego State, Team 1-1, Sheppard Winter 2015 San Diego State, Team 1-1, Sheppard Winter 2015 회원
SDSU-SHEPPARD-W15S1G1
3 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 7
전체 시간: 648
