주요 콘텐츠로 건너뛰기
Pioneer Steel Wheels Folding Hinges Replacement
필요한 것
  1. Pioneer Steel Wheels Folding Hinges Replacement, Headband: 1 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement, Headband: 1 단계, 이미지 2/2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Folding Hinges Replacement: 2 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement: 2 단계, 이미지 2/2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Folding Hinges Replacement: 3 단계, 이미지 1/3 Pioneer Steel Wheels Folding Hinges Replacement: 3 단계, 이미지 2/3 Pioneer Steel Wheels Folding Hinges Replacement: 3 단계, 이미지 3/3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
  4. Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: 4 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement, Folding Hinges: 4 단계, 이미지 2/2
    • While holding the base of the headband with one hand, hold the ear cup with the other hand.
    • Pull them apart to reveal the screw.
  5. Pioneer Steel Wheels Folding Hinges Replacement: 5 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement: 5 단계, 이미지 2/2
    • While apart, remove the screw from the headphone.
  6. Pioneer Steel Wheels Folding Hinges Replacement: 6 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement: 6 단계, 이미지 2/2
    • Loosen the plastic cover piece that protects the chrome folding hinge.
    • Remove the plastic cover piece.
    • During reassembly, make sure the plastic covering piece hooks onto the base of the chrome hinge before screwing it back in.
  7. Pioneer Steel Wheels Folding Hinges Replacement: 7 단계, 이미지 1/2 Pioneer Steel Wheels Folding Hinges Replacement: 7 단계, 이미지 2/2
    • Holding the ear cup with one hand, pull up on the base of the headband with the other hand to release the folding hinge.
    • Repeat for the opposite side if necessary.
결론
Garrett Leung
회원 가입일: 04/16/13
955 평판
안내서 8개 작성하였습니다
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G40
4 회원들
안내서 37개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 464
