주요 콘텐츠로 건너뛰기
Pioneer Steel Wheels Headphone Headband Replacement
필요한 것
  1. Pioneer Steel Wheels Headphone Headband Replacement, Headband: 1 단계, 이미지 1/2 Pioneer Steel Wheels Headphone Headband Replacement, Headband: 1 단계, 이미지 2/2
    • Remove the two screws on the underside of the headband with the PH0 Phillips screw driver.
  2. Pioneer Steel Wheels Headphone Headband Replacement: 2 단계, 이미지 1/2 Pioneer Steel Wheels Headphone Headband Replacement: 2 단계, 이미지 2/2
    • With the headband fully extended, hold the base of the headband with one hand and with your other hand, hold the top of the headband.
    • With force, pull upwards.
  3. Pioneer Steel Wheels Headphone Headband Replacement: 3 단계, 이미지 1/3 Pioneer Steel Wheels Headphone Headband Replacement: 3 단계, 이미지 2/3 Pioneer Steel Wheels Headphone Headband Replacement: 3 단계, 이미지 3/3
    • Remove the rail-piece that is now sticking up by pulling it up and out of the headphone.
    • Repeat on the opposite side and the headband will be released.
    • During reassembly, make the sure the rail-pieces match their respective sides so the headband reinserts properly.
결론
Garrett Leung
회원 가입일: 04/16/13
955 평판
안내서 8개 작성하였습니다
Cal Poly, Team 10-40, Amido Spring 2013 Cal Poly, Team 10-40, Amido Spring 2013 회원
CPSU-AMIDO-S13S10G40
4 회원들
안내서 37개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 1,131
