주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Pipo Smart S1 Battery Replacement
필요한 것
  1. Pipo Smart S1 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Pipo Smart S1 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Pipo Smart S1 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Insert an iFixit opening tool between the body and display of the tablet at the bottom of the device where the charging port is.
    • Slide the tool along the gap you are creating, moving to the right direction against the mini USB port.
  2. Pipo Smart S1 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Gently pry the body of the tablet and pop the back cover open.
    • Lift the back cover of the device and place it on the side.
  3. Pipo Smart S1 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Lift the edge of the white tape with the iFixit opening tool.
  4. Pipo Smart S1 Battery Replacement: 4 단계, 이미지 2개 중 1개 Pipo Smart S1 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Lift the white tape with your fingers, then lift the yellow tape that holds the battery extension.
  5. Pipo Smart S1 Battery Replacement: 5 단계, 이미지 1개 중 1개
    • On the bottom of your tablet, use the Phillips #0 screwdriver to take the two 3mm screws out.
  6. Pipo Smart S1 Battery Replacement: 6 단계, 이미지 2개 중 1개 Pipo Smart S1 Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Lift the headphone jack and move it to the other side, placing it on the surface you are working on.
  7. Pipo Smart S1 Battery Replacement: 7 단계, 이미지 2개 중 1개 Pipo Smart S1 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to pry the battery and detach it from the glue underneath it.
    • Be careful not to pinch the battery—lithium batteries are hazardous and prone to short circuiting, and thus burning and/or exploding.
  8. Pipo Smart S1 Battery Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the battery and place it a little further away from the positive and negative battery wires.
  9. Pipo Smart S1 Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Using your soldering iron, melt the two lead spots to detach the wires.
    • The soldering iron is extremely hot, so handle with caution. Always keep the soldering iron holder next to you when using it so you can return it easily.
    • When reassembling, make sure you solder the right pole to the right spot on the circuit board, as swapping them can burn the motherboard.
  10. Pipo Smart S1 Battery Replacement: 10 단계, 이미지 2개 중 1개 Pipo Smart S1 Battery Replacement: 10 단계, 이미지 2개 중 2개
    • Remove the two wires. Then remove the battery completely from the device.
    • Make sure you tape the negative and positive battery wires to keep them from short-circuiting.
결론
작성자
3다른 기여자 명과 함께
Ali Alqallaf
회원 가입일: 09/28/16
340 평판
안내서 3개를 작성함
USF Tampa, Team 3-6, Passmore Fall 2016 USF Tampa, Team 3-6, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G6
3 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 29
전체 시간: 1,181
