소개
Removing the grip panels allows you to change the battery and allows you to remove the frame, which gives access to more parts of the marker.
필요한 것
Use the 5/64" hex key to remove the screw shown.
Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
