주요 콘텐츠로 건너뛰기
Planet Eclipse Etha Eyes Replacement
필요한 것
  1. Planet Eclipse Etha Eyes Replacement, Regulator: 1 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement, Regulator: 1 단계, 이미지 2/2
    • Firmly grasp hold of the ring on the bottom of the 90 degree silver fitting on the front of the gun.
    • Pull hard, but slowly, on the macroline where it comes out of silver piece until it comes out.
    • The macroline is the black hose connecting the regulator to the tank connection.
  2. Planet Eclipse Etha Eyes Replacement: 2 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement: 2 단계, 이미지 2/2
    • Remove the regulator by unscrewing it in a clockwise direction.
  3. Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: 3 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement, Battery and Grip Panels: 3 단계, 이미지 2/2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  4. Planet Eclipse Etha Eyes Replacement: 4 단계, 이미지 1/1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  5. Planet Eclipse Etha Eyes Replacement: 5 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement: 5 단계, 이미지 2/2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  6. Planet Eclipse Etha Eyes Replacement, Frame: 6 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement, Frame: 6 단계, 이미지 2/2
    • Carefully disconnect the three connectors from the circuit board.
    • Don't worry about remembering which direction the connectors go in, they will not fit in the board in the wrong direction.
  7. Planet Eclipse Etha Eyes Replacement: 7 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement: 7 단계, 이미지 2/2
    • Use the 1/8" hex key to remove the two dome-headed screws by rotating them counter-clockwise.
  8. Planet Eclipse Etha Eyes Replacement: 8 단계, 이미지 1/1
    • Be very careful during the step to avoid damage to the solenoid or wiring.
    • Gently separate the top and bottom of the marker.
  9. Planet Eclipse Etha Eyes Replacement, Eyes: 9 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement, Eyes: 9 단계, 이미지 2/2
    • Use the 5/64" hex key to turn the screw counterclockwise.
    • Carefully remove the screw and place it off to the side.
    • Remove the panel and place it off to the side.
  10. Planet Eclipse Etha Eyes Replacement: 10 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement: 10 단계, 이미지 2/2
    • Carefully flip the marker over.
    • Remove the screw and place it off to the side.
    • Carefully remove the panel and place it off to the side.
  11. Planet Eclipse Etha Eyes Replacement: 11 단계, 이미지 1/2 Planet Eclipse Etha Eyes Replacement: 11 단계, 이미지 2/2
    • Grip the marker with one hand and gently pull the eyes out with your other hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Hannah Lancaster
회원 가입일: 10/14/14
132 평판
안내서 1개 작성함
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G42
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 1,197
