주요 콘텐츠로 건너뛰기
Planet Eclipse Etha Trigger Replacement
필요한 것
  1. Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: 1 단계, 이미지 1/2 Planet Eclipse Etha Trigger Replacement, Battery and Grip Panels: 1 단계, 이미지 2/2
    • Use the 5/64" hex key to remove the screw shown.
    • Remove the grip panel by gently holding the bottom of the panel and lifting the panel off.
    • If you are only replacing the battery, skip the next step.
    • The screws in this guide are interchangeable with those shown in the Eyes replacement guide.
  2. Planet Eclipse Etha Trigger Replacement: 2 단계, 이미지 1/1
    • Flip the marker over and use the 5/64" hex key to remove the screw shown.
  3. Planet Eclipse Etha Trigger Replacement: 3 단계, 이미지 1/2 Planet Eclipse Etha Trigger Replacement: 3 단계, 이미지 2/2
    • Carefully remove the 9V battery and connector.
    • Remove the 9V battery from the connector.
  4. Planet Eclipse Etha Trigger Replacement, Trigger: 4 단계, 이미지 1/1
    • Use a hex key to unscrew the middle screw on the top of the trigger.
  5. Planet Eclipse Etha Trigger Replacement: 5 단계, 이미지 1/1
    • Use same hex key to push through trigger retention pin on the side of the gun.
  6. Planet Eclipse Etha Trigger Replacement: 6 단계, 이미지 1/2 Planet Eclipse Etha Trigger Replacement: 6 단계, 이미지 2/2
    • Pull out the trigger by grabbing the bottom and slowly rotating outwards.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Evan Hench
회원 가입일: 10/19/14
211 평판
안내서 1개 작성함
Cal Poly, Team 10-42, Amido Fall 2014 Cal Poly, Team 10-42, Amido Fall 2014 회원
CPSU-AMIDO-F14S10G42
5 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 10
전체 시간: 941
