소개
This replacement is necessary if the gasket needs replacement.
필요한 것
Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
Remove the solenoid.
Locate the solenoid gasket manifold, underneath the top half of the body.
거의 끝나갑니다!
결론
