주요 콘텐츠로 건너뛰기
Planet Eclipse Geo3 Solenoid Replacement
필요한 것
  1. Planet Eclipse Geo3 Solenoid Replacement, Grip: 1 단계, 이미지 1/2 Planet Eclipse Geo3 Solenoid Replacement, Grip: 1 단계, 이미지 2/2
    • Remove the four screws from the grip with the 5/64" allen wrench. There are two on each side.
  2. Planet Eclipse Geo3 Solenoid Replacement: 2 단계, 이미지 1/2 Planet Eclipse Geo3 Solenoid Replacement: 2 단계, 이미지 2/2
    • Pull the grip away from the frame.
  3. Planet Eclipse Geo3 Solenoid Replacement: 3 단계, 이미지 1/2 Planet Eclipse Geo3 Solenoid Replacement: 3 단계, 이미지 2/2
    • Pull the grip through the opening.
    • The grip is connected in the middle and is one piece.
  4. Planet Eclipse Geo3 Solenoid Replacement, Macroline: 4 단계, 이미지 1/3 Planet Eclipse Geo3 Solenoid Replacement, Macroline: 4 단계, 이미지 2/3 Planet Eclipse Geo3 Solenoid Replacement, Macroline: 4 단계, 이미지 3/3
    • Remove the macroline from the fitting by pulling the metal ring around the end of the fitting away while pulling out the macroline.
    • It helps to rotate the collar to create room to pull out macroline.
  5. Planet Eclipse Geo3 Solenoid Replacement: 5 단계, 이미지 1/3 Planet Eclipse Geo3 Solenoid Replacement: 5 단계, 이미지 2/3 Planet Eclipse Geo3 Solenoid Replacement: 5 단계, 이미지 3/3
    • While pulling in the metal ring on the fitting, pull the macroline out.
  6. Planet Eclipse Geo3 Solenoid Replacement, Body: 6 단계, 이미지 1/3 Planet Eclipse Geo3 Solenoid Replacement, Body: 6 단계, 이미지 2/3 Planet Eclipse Geo3 Solenoid Replacement, Body: 6 단계, 이미지 3/3
    • Use 1/8" allen wrench to remove screw behind regulator.
  7. Planet Eclipse Geo3 Solenoid Replacement: 7 단계, 이미지 1/3 Planet Eclipse Geo3 Solenoid Replacement: 7 단계, 이미지 2/3 Planet Eclipse Geo3 Solenoid Replacement: 7 단계, 이미지 3/3
    • Use 1/8" allen wrench to loosen the screw inside the grip on the right side.
    • The screw only needs to be turned a couple of times.
    • Slide the upper frame forward on the rails and remove the screw from the slot to separate the two halves of the body.
    • BE CAREFUL: Do not pull the two frames apart too much or too quickly. This may cause the wires to be damaged.
  8. Planet Eclipse Geo3 Solenoid Replacement, Solenoid: 8 단계, 이미지 1/3 Planet Eclipse Geo3 Solenoid Replacement, Solenoid: 8 단계, 이미지 2/3 Planet Eclipse Geo3 Solenoid Replacement, Solenoid: 8 단계, 이미지 3/3
    • Using the Phillips #0 screwdriver, remove the 2 screws in the solenoid.
    • Remove the solenoid.
  9. Planet Eclipse Geo3 Solenoid Replacement: 9 단계, 이미지 1/1
    • Pry the board connection with the 2 black wires from the terminal.
    • BE CAREFUL: Do not pull hard by the wires or you may dislodge them from the connection instead of removing the connection from the board.
    • Pull out the wires through the opening in the top of the grip and replace the solenoid.
결론
Rett Triplett
회원 가입일: 10/18/13
801 평판
안내서 8개 작성하였습니다
Clemson, Team 13-6, Benson Fall 2013 Clemson, Team 13-6, Benson Fall 2013 회원
CLEM-BENSON-F13S13G6
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 17
전체 시간: 1,577
