주요 콘텐츠로 건너뛰기
Planet Eclipse LV1 Paintball Marker Eye Replacement
필요한 것
  1. Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: 1 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement, Eye: 1 단계, 이미지 2개 중 2개
    • Remove the four grip screws with a 5/64" Allen wrench. There are two screws on each side of the marker.
  2. Planet Eclipse LV1 Paintball Marker Eye Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the rubber grip.
  3. Planet Eclipse LV1 Paintball Marker Eye Replacement: 3 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 3 단계, 이미지 2개 중 2개
    • On the non-battery side of the marker, unscrew the eye cover with a 5/64" Allen wrench to remove the eye cover.
  4. Planet Eclipse LV1 Paintball Marker Eye Replacement: 4 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 4 단계, 이미지 2개 중 2개
    • On the battery side of the marker, unscrew the other eye cover with a 5/64" Allen wrench to remove the eye cover.
  5. Planet Eclipse LV1 Paintball Marker Eye Replacement: 5 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 5 단계, 이미지 2개 중 2개
    • Pull the red and black eye sensor wires to disconnect the plug from the control board.
  6. Planet Eclipse LV1 Paintball Marker Eye Replacement: 6 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 6 단계, 이미지 2개 중 2개
    • On the battery side of the marker, pull out the red eye sensor wire from the slot.
    • On the non-battery side of the marker, pull out the black eye sensor wire from the slot.
  7. Planet Eclipse LV1 Paintball Marker Eye Replacement: 7 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 7 단계, 이미지 2개 중 2개
    • On the battery side of the marker, grasp the plug to remove the red and black eye sensor wires.
  8. Planet Eclipse LV1 Paintball Marker Eye Replacement: 8 단계, 이미지 1개 중 1개
    • With the new eye, pass the plug in between the solenoid and the grip frame.
  9. Planet Eclipse LV1 Paintball Marker Eye Replacement: 9 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 9 단계, 이미지 2개 중 2개
    • Orient the plug to align with the male receptors of the control board and click into place.
  10. Planet Eclipse LV1 Paintball Marker Eye Replacement: 10 단계, 이미지 1개 중 1개
    • Grasp the black eye sensor wire and pull it completely through and out of the grip frame on the battery side.
    • Keep the black eye sensor wire out of the way until step 13.
  11. Planet Eclipse LV1 Paintball Marker Eye Replacement: 11 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 11 단계, 이미지 2개 중 2개
    • Orient the sensor with the flat side facing up.
    • On the battery side of the marker, place the red eye sensor wire into the slot of the marker.
  12. Planet Eclipse LV1 Paintball Marker Eye Replacement: 12 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 12 단계, 이미지 2개 중 2개
    • Set the eye cover into the slot and secure with the eye cover screw using a 5/64" Allen wrench.
    • Ensure the wires are not pinched between the eye cover and the marker.
  13. Planet Eclipse LV1 Paintball Marker Eye Replacement: 13 단계, 이미지 1개 중 1개
    • On the battery side of the marker, push the black eye sensor wire through the grip frame and under the solenoid.
  14. Planet Eclipse LV1 Paintball Marker Eye Replacement: 14 단계, 이미지 1개 중 1개
    • On the non-battery side of the marker, pull through the black eye sensor wire completely.
  15. Planet Eclipse LV1 Paintball Marker Eye Replacement: 15 단계, 이미지 1개 중 1개
    • On the non-battery side of the marker, place the black eye sensor wire into the slot of the marker.
  16. Planet Eclipse LV1 Paintball Marker Eye Replacement: 16 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 16 단계, 이미지 2개 중 2개
  17. Planet Eclipse LV1 Paintball Marker Eye Replacement: 17 단계, 이미지 1개 중 1개
    • Reinstall the rubber grip.
  18. Planet Eclipse LV1 Paintball Marker Eye Replacement: 18 단계, 이미지 2개 중 1개 Planet Eclipse LV1 Paintball Marker Eye Replacement: 18 단계, 이미지 2개 중 2개
    • Secure the rubber grip with the four grip screws using a 5/64" Allen wrench. There are two screws on each side.
결론
Thank you for viewing this step-by-step guide on replacing an eye for a Planet Eclipse LV1 Paintball Marker. Now get back out there and have fun!
작성자
1다른 기여자 명과 함께
Jessica
회원 가입일: 09/18/24
277 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 8
전체 시간: 177
