주요 콘텐츠로 건너뛰기
Plantronics CS50 Headset Motherboard Replacement
필요한 것
  1. Plantronics CS50 Headset Motherboard Replacement, Battery: 1 단계, 이미지 1/3 Plantronics CS50 Headset Motherboard Replacement, Battery: 1 단계, 이미지 2/3 Plantronics CS50 Headset Motherboard Replacement, Battery: 1 단계, 이미지 3/3
    • Flip the headset face down.
    • Squeeze both sides of the battery cover.
    • While squeezing, pull the cover up slowly to remove it.
  2. Plantronics CS50 Headset Motherboard Replacement: 2 단계, 이미지 1/3 Plantronics CS50 Headset Motherboard Replacement: 2 단계, 이미지 2/3 Plantronics CS50 Headset Motherboard Replacement: 2 단계, 이미지 3/3
    • Locate and detatch the white connector that connects the wires of the battery to the wires of the headset.
  3. Plantronics CS50 Headset Motherboard Replacement, Microphone: 3 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement, Microphone: 3 단계, 이미지 2/2
    • Use a hairdryer or heat gun to melt the adhesive along the crevice that joins the black and silver components.
    • Apply additional heat at the tip of the microphone.
  4. Plantronics CS50 Headset Motherboard Replacement: 4 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement: 4 단계, 이미지 2/2
    • After heating the headset, use the plastic opening tool to carefully pry the black cover from the headset.
    • Be aware of the two plastic connectors inside the headset. If the black cover does not come off smoothly, apply additional heat on the connectors.
  5. Plantronics CS50 Headset Motherboard Replacement: 5 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the microphone from the tip of the plastic.
    • You will have to lift the microphone straight up because it is held in place by a small piece of plastic.
  6. Plantronics CS50 Headset Motherboard Replacement: 6 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement: 6 단계, 이미지 2/2
    • Use the heat gun to melt the adhesive connecting the headset face to the speaker casing.
    • Use the plastic opening tool to separate the speaker casing from the headset face.
    • Add extra heat to the sides to melt the adhesive between the plastic connectors.
  7. Plantronics CS50 Headset Motherboard Replacement: 7 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement: 7 단계, 이미지 2/2
    • Slowly separate the motherboard from the rest of the headset.
  8. Plantronics CS50 Headset Motherboard Replacement: 8 단계, 이미지 1/1
    • Locate the microphone wires on the bottom of the motherboard.
    • Use a hairdryer or heat gun to melt the glue off of the motherboard.
  9. Plantronics CS50 Headset Motherboard Replacement: 9 단계, 이미지 1/1
    • Flip the device over.
    • Use a soldering iron to remove the solder that holds the wires to the motherboard.
    • For help soldering, click here.
    • The microphone piece should be completely detached from the motherboard.
  10. Plantronics CS50 Headset Motherboard Replacement, Motherboard: 10 단계, 이미지 1/3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: 10 단계, 이미지 2/3 Plantronics CS50 Headset Motherboard Replacement, Motherboard: 10 단계, 이미지 3/3
    • Using a blow dryer or a heat gun, heat the crevice to melt the adhesive between the plastic covers.
    • Using a plastic opening tool, prop open the edges.
    • Gently pull the black speaker casing up to remove it.
  11. Plantronics CS50 Headset Motherboard Replacement: 11 단계, 이미지 1/2 Plantronics CS50 Headset Motherboard Replacement: 11 단계, 이미지 2/2
    • Use the heat gun or blow dryer to melt the glue that connects the wires to the headset's motherboard.
    • The wires should come off as they are not soldered to the motherboard.
결론
Joe
회원 가입일: 04/12/12
99 평판
안내서 3개 작성하였습니다
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G29
4 회원들
안내서 7개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 2
전체 시간: 978
