주요 콘텐츠로 건너뛰기
Plantronics CS50 Headset System Reset
  1. Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: 1 단계, 이미지 2개 중 1개 Plantronics CS50 Headset System Reset, Plantronics CS50 Headset System Reset: 1 단계, 이미지 2개 중 2개
    • Press and hold both the call control button and the listening volume/mute button for five seconds.
    • When the talk indicator light blinks, release both buttons.
  2. Plantronics CS50 Headset System Reset: 2 단계, 이미지 1개 중 1개
    • Press the call control button again.
  3. Plantronics CS50 Headset System Reset: 3 단계, 이미지 2개 중 1개 Plantronics CS50 Headset System Reset: 3 단계, 이미지 2개 중 2개
    • Unplug the base unit's power source for ten seconds.
    • Plug the power source back in.
결승점
다른 3명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Joe
회원 가입일: 04/12/12
117 평판
안내서 3개를 작성함
Cal Poly, Team 17-29, Amido Spring 2012 Cal Poly, Team 17-29, Amido Spring 2012 회원
CPSU-AMIDO-S12S17G29
4 회원들
안내서 7개를 작성함
4가이드 댓글
Great fix. I was about to spend $200 on a new set. Thanks.
acseko - 답글
I had a constant buzzing sound from the unit. I did what you recommended and could not stop it. Then I discovered that my handset also had the same buzzing sound so I unplugged the phone line and power cord (to the main phone unit) and it cleared up!
Russ - 답글
I've got a unit that is getting no sound to or from the earpiece at all, though the lifter still lifts when I hit the answer button. I'll try this reset before I order a replacement set.
kool1zero - 답글
I have the C053 model and have cleaned headset and base and can not get it to charge. I have noticed over the past few weeks that it will only stayed charged from 800 am to 100 pm. I have disconnected and restarted also. Any other suggestions?
Diane
Diane - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 10
지난 30일: 26
전체 시간: 23,104
