소개
The earpiece unit on the Plantronics Voyager Legend consists of a soft-plastic earpiece, a plastic housing, a wire assembly, and the actual speaker unit. The assembly is held together by glue and snaps making disassembly difficult.
필요한 것
Remove the soft, plastic earpiece.
Depress the soft, plastic earpiece. While depressed, rotate the earpiece counterclockwise ninety degrees.
List the soft, plastic earpiece out of its position.
다른 7명이 해당 안내서를 완성하였습니다.
댓글 한 개
Thank you for the Guide.
One further Question is open for me: How do you replace the broken rubber near the earpiece?
