주요 콘텐츠로 건너뛰기
HP Photosmart 935 Plastic Casing Replacement
필요한 것
  1. HP Photosmart 935 Plastic Casing Replacement, Batteries: 1 단계, 이미지 1/2 HP Photosmart 935 Plastic Casing Replacement, Batteries: 1 단계, 이미지 2/2
    • Flip the camera over so the bottom of the camera is facing you.
    • Turn the mode dial to the OFF position.
  2. HP Photosmart 935 Plastic Casing Replacement: 3 단계, 이미지 1/2 HP Photosmart 935 Plastic Casing Replacement: 3 단계, 이미지 2/2
    • Slide the bottom cover in the direction of the arrow to open it.
  3. HP Photosmart 935 Plastic Casing Replacement: 4 단계, 이미지 1/1
    • Pull out the batteries.
  4. HP Photosmart 935 Plastic Casing Replacement, Plastic Casing: 5 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the two 4.7 mm screws in the bottom of the plastic casing.
  5. HP Photosmart 935 Plastic Casing Replacement: 6 단계, 이미지 1/2 HP Photosmart 935 Plastic Casing Replacement: 6 단계, 이미지 2/2
    • Remove the four 4.7 mm screws on the left side of the camera.
  6. HP Photosmart 935 Plastic Casing Replacement: 7 단계, 이미지 1/2 HP Photosmart 935 Plastic Casing Replacement: 7 단계, 이미지 2/2
    • Remove the four 4.7 mm screws on the opposite side of the camera.
  7. HP Photosmart 935 Plastic Casing Replacement: 8 단계, 이미지 1/3 HP Photosmart 935 Plastic Casing Replacement: 8 단계, 이미지 2/3 HP Photosmart 935 Plastic Casing Replacement: 8 단계, 이미지 3/3
    • Use your thumbs to pry the case apart.
    • It is easiest to pry the case apart if you start at the bottom.
    • The case should come apart with minimal effort. If it doesn't, you can use a spudger or plastic opening tool to pry it open.
  8. HP Photosmart 935 Plastic Casing Replacement: 9 단계, 이미지 1/1
    • This step requires a significant amount of force.
    • Pull the bottom half of the inner camera out of the case by half an inch. This may be difficult.
  9. HP Photosmart 935 Plastic Casing Replacement: 10 단계, 이미지 1/2 HP Photosmart 935 Plastic Casing Replacement: 10 단계, 이미지 2/2
    • While pulling the camera out of the case, note the small soft plastic cover on the side. This cover will detach from the rest of the device.
    • Once the bottom of the inner camera is pulled out, pull the device out completely.
    • Use a firm grasp when removing the device from the case for stability and control.
결론
Clay Young
회원 가입일: 04/04/12
233 평판
안내서 2개 작성하였습니다
Cal Poly, Team 15-13, Forte Spring 2012 Cal Poly, Team 15-13, Forte Spring 2012 회원
CPSU-FORTE-S12S15G13
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 1,739
