소개
Remove and replace your PlayStation 2's power board.
필요한 것
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
다른 36명이 해당 안내서를 완성하였습니다.
댓글 5개
Where do I buy the new Power Board?
Where can you buy a new power board?
Merci beaucoup, vous êtes le meilleur et le meilleur
Rahef Love - 답글
