소개
Remove and replace your PlayStation 2's power board.
필요한 것
Use the flat edge of a metal spudger to pry the eight flat screw covers out.
Remove the following eight screws securing the top cover to the bottom case:
Four 55.4 mm Philips screws
Four 18.0 mm Phillips screws
Lift the top cover off the bottom case.
Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
If you have a 5000x model, then the power and reset buttons are attached to the console, not the lid. Therefore there won’t be a cord
Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
Lift and remove the optical disc drive straight up out of the bottom case.
Gently lift the controller port board out of its recess within the bottom case.
Pull the controller port ribbon cable straight away from its socket on the controller port board.
Remove the controller port board out of the bottom case.
El conector del flex del modulo de conectores de los mando y las memory card no va a presión, para volver a colocarlo, hay que abrirlo.
Controller is detached can we fix it?
The clip which holds the controller is broken
Pry and remove the expansion bay cover away from its posts on the bottom case.
If there is a harddrive in the system place switch on off position before removing and reinstalling because it may blow the fuse that runs the harddrive!
Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
If you have a 5000x model, then the power supply will be flipped upside down (or right side up). the screws are in the same positions
다른 36명이 해당 안내서를 완성하였습니다.
댓글 5개
Where do I buy the new Power Board?
Where can you buy a new power board?
Merci beaucoup, vous êtes le meilleur et le meilleur
Rahef Love - 답글
Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
Tristan - 답글
Ich möchte daraufhin weisen, daß es bei der SCPH-50004 zwei verschiedene Schraubabdeckungen gibt.
4x Kreuzförmig 4x rechteckig
Sowie eine silberne schraube die sich an der unterseite aufhöhe des Reset-Knopfes befindet.
Christian Lehnhardt - 답글
