주요 콘텐츠로 건너뛰기
PlayStation 2 Power Board Replacement
필요한 것
  1. PlayStation 2 Power Board Replacement, Top Cover: 1 단계, 이미지 1/3 PlayStation 2 Power Board Replacement, Top Cover: 1 단계, 이미지 2/3 PlayStation 2 Power Board Replacement, Top Cover: 1 단계, 이미지 3/3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
    Before proceeding to step 2, Take a look at your PS2, some PS2's have 10 screws (and screw covers) instead of 8 (i found them underneath the optical drive), these instructions have mislead me and i ended up breaking my top cover for my PS2.
    Tristan - 답글
    Ich möchte daraufhin weisen, daß es bei der SCPH-50004 zwei verschiedene Schraubabdeckungen gibt.
    4x Kreuzförmig 4x rechteckig
    Sowie eine silberne schraube die sich an der unterseite aufhöhe des Reset-Knopfes befindet.
    Christian Lehnhardt - 답글
  2. PlayStation 2 Power Board Replacement: 2 단계, 이미지 1/1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Power Board Replacement: 3 단계, 이미지 1/1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Power Board Replacement: 4 단계, 이미지 1/2 PlayStation 2 Power Board Replacement: 4 단계, 이미지 2/2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
    If you have a 5000x model, then the power and reset buttons are attached to the console, not the lid. Therefore there won’t be a cord
    ARandomGuy231 - 답글
  5. PlayStation 2 Power Board Replacement, Power Board: 5 단계, 이미지 1/2 PlayStation 2 Power Board Replacement, Power Board: 5 단계, 이미지 2/2
    • Remove the two 6.4 mm black Phillips screws securing the optical disc drive to the bottom case.
    • Lift and remove the optical disc drive straight up out of the bottom case.
  6. PlayStation 2 Power Board Replacement: 6 단계, 이미지 1/2 PlayStation 2 Power Board Replacement: 6 단계, 이미지 2/2
    • Remove the two 14.6 mm gold-headed Phillips securing the controller ports to the bottom case.
  7. PlayStation 2 Power Board Replacement: 7 단계, 이미지 1/2 PlayStation 2 Power Board Replacement: 7 단계, 이미지 2/2
    • Gently lift the controller port board out of its recess within the bottom case.
    • Do not completely remove the controller port board. It is still attached via a ribbon cable.
    • Pull the controller port ribbon cable straight away from its socket on the controller port board.
    • Remove the controller port board out of the bottom case.
    El conector del flex del modulo de conectores de los mando y las memory card no va a presión, para volver a colocarlo, hay que abrirlo.
    Marcos Morán - 답글
    Controller is detached can we fix it?
    The clip which holds the controller is broken
    sravan kumbum - 답글
  8. PlayStation 2 Power Board Replacement: 8 단계, 이미지 1/1
    • Remove the two 14.6 mm gold Phillips screws securing the fan to the bottom case.
  9. PlayStation 2 Power Board Replacement: 9 단계, 이미지 1/1
    • If there is a device occupying the expansion bay, make sure to remove the device. The expansion base should be empty.
    • Pry and remove the expansion bay cover away from its posts on the bottom case.
    If there is a harddrive in the system place switch on off position before removing and reinstalling because it may blow the fuse that runs the harddrive!
    stephen harrison - 답글
  10. PlayStation 2 Power Board Replacement: 10 단계, 이미지 1/1
    • Lift the motherboard assembly from its front edge and remove it from the lower case.
  11. PlayStation 2 Power Board Replacement: 11 단계, 이미지 1/1
    • Now that all of that bulky plastic is out of the way, we can get to the fun stuff - electronics!
    • Remove the four 7.6 mm gold-head Phillips securing the power supply to the motherboard assembly.
    If you have a 5000x model, then the power supply will be flipped upside down (or right side up). the screws are in the same positions
    ARandomGuy231 - 답글
  12. PlayStation 2 Power Board Replacement: 12 단계, 이미지 1/1
    • Lift the expansion bay cage up off the motherboard assembly.
  13. PlayStation 2 Power Board Replacement: 13 단계, 이미지 1/2 PlayStation 2 Power Board Replacement: 13 단계, 이미지 2/2
    • Do not remove the power board yet. It is still attached to the motherboard assembly via the power board connector (highlighted in the first picture), which is located next to the main power switch.
    • Carefully lift the power board. You should now see the power board connector attached to the power board.
    • Pull the power board connector straight to lift it out of its socket on the power board.
결론
다른 36명이 해당 안내서를 완성하였습니다.
jwyoung
회원 가입일: 11/04/09
2,809 평판
안내서 5개 작성하였습니다
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 회원
CPSU-MANESS-F09S19G1
4 회원들
안내서 34개 작성하였습니다
댓글 5개
Where do I buy the new Power Board?
chanceman75 - 답글
Where can you buy a new power board?
Logan Jorgensen - 답글
Can u replace the fuse.?
brincp - 답글
good news for us
VBlakeney - 답글
Merci beaucoup, vous êtes le meilleur et le meilleur
Rahef Love - 답글
댓글 쓰기
조회 통계:
24 시간 전: 9
7일 전: 77
30일 전: 407
전체 시간: 39,406
