주요 콘텐츠로 건너뛰기
PlayStation 2 Slimline IR Sensor Replacement
필요한 것
  1. PlayStation 2 Slimline IR Sensor Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline IR Sensor Replacement: 2 단계, 이미지 1/3 PlayStation 2 Slimline IR Sensor Replacement: 2 단계, 이미지 2/3 PlayStation 2 Slimline IR Sensor Replacement: 2 단계, 이미지 3/3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline IR Sensor Replacement: 3 단계, 이미지 1/3 PlayStation 2 Slimline IR Sensor Replacement: 3 단계, 이미지 2/3 PlayStation 2 Slimline IR Sensor Replacement: 3 단계, 이미지 3/3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline IR Sensor Replacement: 4 단계, 이미지 1/3 PlayStation 2 Slimline IR Sensor Replacement: 4 단계, 이미지 2/3 PlayStation 2 Slimline IR Sensor Replacement: 4 단계, 이미지 3/3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline IR Sensor Replacement, IR Sensor: 5 단계, 이미지 1/1
    • Locate the IR sensor at the front, right corner of the unit.
  6. PlayStation 2 Slimline IR Sensor Replacement: 6 단계, 이미지 1/1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  7. PlayStation 2 Slimline IR Sensor Replacement: 7 단계, 이미지 1/1
    • Gently lift and remove the IR Sensor from its designated slot.
결론
다른 8명이 해당 안내서를 완성하였습니다.
Thomas Sullivan
회원 가입일: 10/23/13
3,927 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 25
30일 전: 99
전체 시간: 6,873
