주요 콘텐츠로 건너뛰기
PlayStation 2 Slimline Motherboard Replacement
필요한 것
  1. PlayStation 2 Slimline Motherboard Replacement, Outer Shell: 1 단계, 이미지 1/1
    • Disconnect all cables from the console and flip the unit over to reveal its base.
  2. PlayStation 2 Slimline Motherboard Replacement: 2 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 2 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 2 단계, 이미지 3/3
    • Locate the 6 feet on the base of the unit. Pry them off using a spudger to reveal the screws.
    • Note: One of the feet is located under the sticker shown in the photo. Removing this sticker will void any warranty with Sony.
  3. PlayStation 2 Slimline Motherboard Replacement: 3 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 3 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 3 단계, 이미지 3/3
    • Remove all six 4.0 mm screws from the base of the unit using a #1 Phillips screwdriver.
  4. PlayStation 2 Slimline Motherboard Replacement: 4 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 4 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 4 단계, 이미지 3/3
    • Starting at the corner at which the power and Ethernet ports are located, pry open the outer shell using a spudger and continue around the entire unit.
    • Note: You may use your hands for additional force to separate the two pieces of the outer shell.
  5. PlayStation 2 Slimline Motherboard Replacement, Fan: 5 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement, Fan: 5 단계, 이미지 2/2
    • Locate the fan at the front, left section of the unit.
  6. PlayStation 2 Slimline Motherboard Replacement: 6 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement: 6 단계, 이미지 2/2
    • Peel off the sticker holding the power cords to the unit.
  7. PlayStation 2 Slimline Motherboard Replacement: 7 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Lift the connector from the motherboard with a pair of tweezers using a firm, upward force.
  8. PlayStation 2 Slimline Motherboard Replacement: 8 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 8 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 8 단계, 이미지 3/3
    • Remove all three 1.6 mm screws fastening the fan to the unit using a #1 Phillips screwdriver.
    • Gently lift and remove the fan from its compartment.
  9. PlayStation 2 Slimline Motherboard Replacement, Clock Battery: 9 단계, 이미지 1/1
    • Locate the clock battery at the front, right section of the unit. The battery has a circular shape with red (+) and black (-) wires connecting to the motherboard.
  10. PlayStation 2 Slimline Motherboard Replacement: 10 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
  11. PlayStation 2 Slimline Motherboard Replacement: 11 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement: 11 단계, 이미지 2/2
    • Gently lift and remove the battery from its compartment using a spudger.
  12. PlayStation 2 Slimline Motherboard Replacement, IR Sensor: 12 단계, 이미지 1/1
    • Locate the IR sensor at the front, right corner of the unit.
  13. PlayStation 2 Slimline Motherboard Replacement: 13 단계, 이미지 1/1
    • Gently detach the ribbon cable connecting the IR sensor to the motherboard.
    • Caution: Always remove ribbon cables by the plastic handles located on either end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  14. PlayStation 2 Slimline Motherboard Replacement: 14 단계, 이미지 1/1
    • Gently lift and remove the IR Sensor from its designated slot.
  15. PlayStation 2 Slimline Motherboard Replacement, Optical Drive: 15 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement, Optical Drive: 15 단계, 이미지 2/2
    • Locate the optical drive which occupies most of the space on the right side of the unit. It can be identified by the four screws with wide-diameter heads fastening the optical drive to the motherboard.
  16. PlayStation 2 Slimline Motherboard Replacement: 16 단계, 이미지 1/2 PlayStation 2 Slimline Motherboard Replacement: 16 단계, 이미지 2/2
    • Remove the four 4.0 mm screws using a #1 Phillips screwdriver.
  17. PlayStation 2 Slimline Motherboard Replacement: 17 단계, 이미지 1/1
    • Locate the three ribbon cables connecting the optical drive to the motherboard.
  18. PlayStation 2 Slimline Motherboard Replacement: 18 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 18 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 18 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Gently detach the ribbon cables from the motherboard using a pair of tweezers.
    • Note: The ribbon cable in the center must be unlocked by lifting up the black tab. Remember to push the tab down upon re-installation to secure the cable.
    • Caution: Always remove ribbon cables by the plastic handles located on each end. Gripping a ribbon cable anywhere but the provided handles can damage the cable and render the component useless.
  19. PlayStation 2 Slimline Motherboard Replacement: 19 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 19 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 19 단계, 이미지 3/3
    • Remove any tape fastening the cables to the motherboard and gently lift and remove the optical drive.
  20. PlayStation 2 Slimline Motherboard Replacement, Motherboard: 20 단계, 이미지 1/1
    • Remove the 2.4 mm screw located in between the controller ports using a #1 Phillips screwdriver.
  21. PlayStation 2 Slimline Motherboard Replacement: 21 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 21 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 21 단계, 이미지 3/3
    • Gently lift and remove the motherboard and chassis from the outer shell.
  22. PlayStation 2 Slimline Motherboard Replacement: 22 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 22 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 22 단계, 이미지 3/3
    • There are a total of five 1.6 mm screws which mount the metal chassis to the motherboard.
    • Remove the screw on top and the four screws on the bottom with a #1 Phillips screwdriver.
  23. PlayStation 2 Slimline Motherboard Replacement: 23 단계, 이미지 1/3 PlayStation 2 Slimline Motherboard Replacement: 23 단계, 이미지 2/3 PlayStation 2 Slimline Motherboard Replacement: 23 단계, 이미지 3/3
    • Gently separate the two metal plates from the motherboard.
결론
다른 33명이 해당 안내서를 완성하였습니다.
Thomas Sullivan
회원 가입일: 10/23/13
3,927 평판
안내서 6개 작성하였습니다
댓글 2개
نرجو اضافة اللغة العربية
Muammar lmgaroush - 답글
Mi placa no tiene corriente, seguro tiene un corto quien me ayuda a solucionar, es la 77001, ya tiene botón y flex nuevo y no me da luz Led
gasper6913 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 6
7일 전: 47
30일 전: 244
전체 시간: 25,115
