주요 콘텐츠로 건너뛰기
PlayStation 2 Slimline Optical Drive Replacement
필요한 것
  1. PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 1 단계, 이미지 1/3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 1 단계, 이미지 2/3 PlayStation 2 Slimline Optical Drive Replacement, Optical Drive: 1 단계, 이미지 3/3
    • Remove the rubber feet on two of the screw covers on the bottom of the console.
    • Remove the screw covers and the screws themselves.
    • Caution: One of the screws is underneath the "Do not void" seal
  2. PlayStation 2 Slimline Optical Drive Replacement: 2 단계, 이미지 1/2 PlayStation 2 Slimline Optical Drive Replacement: 2 단계, 이미지 2/2
    • If all screws are removed.
    • Use a metal spunger to open the chassis
  3. PlayStation 2 Slimline Optical Drive Replacement: 3 단계, 이미지 1/3 PlayStation 2 Slimline Optical Drive Replacement: 3 단계, 이미지 2/3 PlayStation 2 Slimline Optical Drive Replacement: 3 단계, 이미지 3/3
    • Slip the three cables out of the sockets.
    • Use a PH01 screwdriver to remove the four screws securing the optical drive
    • Lift up the optical drive and remove the duct tape under the flex cable.
    • Now the optical drive is free and ready for replacement
결론
다른 16명이 해당 안내서를 완성하였습니다.
tlroesner
회원 가입일: 05/13/12
1,864 평판
안내서 4개 작성하였습니다
댓글 3개
How is it that this guide says difficult and the other PS2 drive replacement on here says easy?
Mark - 답글
it really depends on your level of skill/experience.
Damien Simons -
How many different versions of drive is there for the slim model? When you go to replace it, do you just compare the model number on the laser?
Trevor V - 답글
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 18
30일 전: 96
전체 시간: 21,994
