이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide will walk you through step-by-step on how to properly remove and install the clock battery in the PlayStation 2 Slimline.
필요한 것
1 단계 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
주의: 1-7 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Locate the clock battery. Take tweezers and lift up the connector from the motherboard.
다른 8명이 해당 안내서를 완성하였습니다.
댓글 한 개
These instructions take for granted how the battery itself should be replaced. I imagine you reconnect the contact with the red wire to the positive side of the CR2032 battery and the contact for the black wire to the negative and wrap electrical tape around the entire thing BEFORE reconnecting it and then following these instructions in reverse order.
