주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
PlayStation 2 Slimline SCPH-7500x Fan Replacement
필요한 것
  1. 주의: 1-7 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  2. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 2 단계, 이미지 1/1
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  3. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 3 단계, 이미지 1/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 3 단계, 이미지 2/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 3 단계, 이미지 3/3
    • Remove the five visible feet from the bottom of the device using a spudger.
  4. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 4 단계, 이미지 1/2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 4 단계, 이미지 2/2
    • Remove the sticker and then remove the 6th foot.
  5. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 5 단계, 이미지 1/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 5 단계, 이미지 2/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 5 단계, 이미지 3/3
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  6. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 6 단계, 이미지 1/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 6 단계, 이미지 2/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 6 단계, 이미지 3/3
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  7. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 7 단계, 이미지 1/1
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  8. PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 8 단계, 이미지 1/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 8 단계, 이미지 2/3 PlayStation 2 Slimline SCPH-7500x Fan Replacement, Fan: 8 단계, 이미지 3/3
    • Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  9. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 9 단계, 이미지 1/2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 9 단계, 이미지 2/2
    • With tweezers, detach the terminal to the cord from the motherboard to the fan.
  10. PlayStation 2 Slimline SCPH-7500x Fan Replacement: 10 단계, 이미지 1/2 PlayStation 2 Slimline SCPH-7500x Fan Replacement: 10 단계, 이미지 2/2
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Jared Hirata
회원 가입일: 04/09/13
880 평판
안내서 7개 작성하였습니다
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 회원
CPSU-REGAN-S13S17G4
3 회원들
안내서 28개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 11
30일 전: 58
전체 시간: 3,848
