주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
This guide will walk you through step-by-step on how to properly remove and install the motherboard in the PlayStation 2 Slimline.
    • Turn off the PlayStation 2 (or PS2) and carefully unplug from the power source. Check to see there are no discs inside the console before flipping the game system upside-down.
  1. Locate the six feet on the bottom of the PS2.
    • Locate the six feet on the bottom of the PS2.
    • Five of the feet are in plain sight and one of the feet is located under the black void sticker on the bottom of the device.
    • IMPORTANT: Removing the black VOID sticker will void the warranty of this device. Proceed at your own risk
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or even the screw should be in plain sight.
  2. Pry apart the five visible feet from the bottom of the device using a spudger, flathead screwdriver, or fingernail. Pry apart the five visible feet from the bottom of the device using a spudger, flathead screwdriver, or fingernail. Pry apart the five visible feet from the bottom of the device using a spudger, flathead screwdriver, or fingernail.
    • Pry apart the five visible feet from the bottom of the device using a spudger, flathead screwdriver, or fingernail.
  3. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath. The sixth foot is located under the black VOID sticker.  Remove the sticker before  removing the foot underneath.
    • The sixth foot is located under the black VOID sticker. Remove the sticker before removing the foot underneath.
  4. After all of the feet have been removed,  Use a #1 Phillips screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a #1 Phillips screwdriver to remove the six 4.0mm screws from the base of the PS2. After all of the feet have been removed,  Use a #1 Phillips screwdriver to remove the six 4.0mm screws from the base of the PS2.
    • After all of the feet have been removed, Use a #1 Phillips screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves. Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
    • Once all of the screws have been removed, pull apart the top plastic cover from the bottom plastic cover. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate. It will take force to pull apart the two halves.
  6. If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard. Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
    • Locate the IR sensor on the motherboard. Once you locate the IR sensor, use tweezers to gently detach the blue/white ribbon that attaches the IR sensor to the motherboard.
  8. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard. Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
    • Identify the clock battery, then use tweezers to disconnect the connector from the motherboard.
  9. Gently lift up the battery from the battery compartment using the spudger or flathead screwdriver. Gently lift up the battery from the battery compartment using the spudger or flathead screwdriver.
    • Gently lift up the battery from the battery compartment using the spudger or flathead screwdriver.
  10. Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring. Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring. Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
    • Locate the fan component of the motherboard of the PS2. With your fingers or tweezers, peel off the sticker that holds down the fan's wiring.
  11. With tweezers, detach the terminal to the cord from the motherboard to the fan. With tweezers, detach the terminal to the cord from the motherboard to the fan.
    • With tweezers, detach the terminal to the cord from the motherboard to the fan.
  12. Locate and unscrew the three 1.6mm screws located next to the base of the fan. Locate and unscrew the three 1.6mm screws located next to the base of the fan.
    • Locate and unscrew the three 1.6mm screws located next to the base of the fan.
  13. Locate the optical drive on the motherboard. Locate the optical drive on the motherboard.
    • Locate the optical drive on the motherboard.
  14. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard. Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  15. Locate the three ribbons that are attached to the motherboard.
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  16. With tweezers, gently detach all three ribbons from the motherboard terminal.  Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it. IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
    • With tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon by using tweezers to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  17. Gently lift the optical drive away from the motherboard. Gently lift the optical drive away from the motherboard. Gently lift the optical drive away from the motherboard.
    • Gently lift the optical drive away from the motherboard.
  18. What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
    • What you see in this picture is the electronic components found in the PS2. We are now going to remove the top metal casing found on top of the motherboard.
  19. Locate the one 2.4mm screw that mounts the metal casing to the top of the motherboard and unscrew the screw with a Philips Screwdriver.
    • Locate the one 2.4mm screw that mounts the metal casing to the top of the motherboard and unscrew the screw with a Philips Screwdriver.
  20. Gently lift the metal casing from the motherboard. Then lift the motherboard from the plastic outer shell.
    • Gently lift the metal casing from the motherboard.
    • Then lift the motherboard from the plastic outer shell.
    • You should have three separate components: The metal casing, the motherboard and the top half of the outer shell of the PS2.
  21. Flip the motherboard over. Locate and unscrew all five 1.6mm screws that mount the metal plate to the motherboard.
    • Flip the motherboard over.
    • Locate and unscrew all five 1.6mm screws that mount the metal plate to the motherboard.
    • Note that there are four on one side and one on the other.
  22. Gently lift the metal plates from the top and the bottom of the motherboard. Gently lift the metal plates from the top and the bottom of the motherboard.
    • Gently lift the metal plates from the top and the bottom of the motherboard.
  23. Remove the plastic film that is sandwiched in between the metal plate and the motherboard.
    • Remove the plastic film that is sandwiched in between the metal plate and the motherboard.
  24. After you have detached all the other components, it should look like the image shown. After you have detached all the other components, it should look like the image shown.
    • After you have detached all the other components, it should look like the image shown.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jared Hirata
회원 가입일: 2013년 04월 09일
595 평판
안내서 7개 작성하였습니다
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 회원
CPSU-REGAN-S13S17G4
3 회원들
안내서 14개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 13
전체 시간: 5,725
