주요 콘텐츠로 건너뛰기
PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement
필요한 것
    • Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
  1. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Locate the six feet on the bottom of the PS2.
    • Five of these feet are in plain sight while the last foot is located under the black void sticker on the back of the device.
    • Some versions of the console, such as the PAL Version, may not have this sticker. In this case, the foot or the screw should be in plain sight.
  2. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 3 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 3 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the five visible feet from the bottom of the device using a spudger.
  3. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 4 단계, 이미지 2개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the sticker and then remove the 6th foot.
  4. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 5 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 5 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 5 단계, 이미지 3개 중 3개
    • After all of the feet have been removed, Use a Phillips #1 screwdriver to remove the six 4.0mm screws from the base of the PS2.
  5. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 6 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 6 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 6 단계, 이미지 3개 중 3개
    • Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
    • You may need to apply some gentle force to detach the covers. Be careful not to break the plastic screw pins.
  6. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 7 단계, 이미지 1개 중 1개
    • If done correctly, you should have a fully detached plastic backing, revealing the electronic components of the PlayStation 2.
  7. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement, Optical Drive: 8 단계, 이미지 2개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement, Optical Drive: 8 단계, 이미지 2개 중 2개
    • Locate the optical drive on the motherboard.
  8. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 9 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 9 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 9 단계, 이미지 3개 중 3개
    • Unscrew the four 4.0mm screws that mount the optical drive to the motherboard.
  9. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Locate the three ribbons that are attached to the motherboard.
    • Note: These ribbons are different sizes: one large, one medium and one small sized ribbon.
  10. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 11 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 11 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Using tweezers, gently detach all three ribbons from the motherboard terminal. Unlock the middle orange ribbon to lift the black tab up on either side.
    • IMPORTANT: The orange ribbon is glued to the metal chassis. Gently pull the ribbon upward to make sure that you don't rip it.
  11. PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 12 단계, 이미지 3개 중 1개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 12 단계, 이미지 3개 중 2개 PlayStation 2 Slimline SCPH-7500x Optical Drive Replacement: 12 단계, 이미지 3개 중 3개
    • Gently lift the optical drive away from the motherboard.
결론
다른 13명이 해당 안내서를 완성하였습니다.
작성자
14다른 기여자 명과 함께
Jared Hirata
회원 가입일: 04/09/13
986 평판
안내서 7개를 작성함
Cal Poly, Team 17-4, Regan Spring 2013 Cal Poly, Team 17-4, Regan Spring 2013 회원
CPSU-REGAN-S13S17G4
3 회원들
안내서 28개를 작성함
1가이드 댓글
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
Fernando Salazar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 133
전체 시간: 7,485
