소개
This guide will walk you through step-by-step on how to properly remove and install the optical drive in the PlayStation 2 Slimline.
필요한 것
1 단계 Removing Playstation 2 Slimline SCPH-7500x Outer Shell
주의: 1-7 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Turn off the PlayStation 2 and carefully unplug it from the power source. Also, it is important to eject the CD from the console before flipping the it upside down.
Once all of the screws have been removed, pry apart the plastic covers. Start by lifting the side containing the power cable and Ethernet port. Then, lift the opposite side to fully separate the two sides.
It took force to open it, but i broke a plastic pin where the screws enter
You can use a pick to get the thin edge up without breaking anything.
다른 11명이 해당 안내서를 완성하였습니다.
댓글 한 개
I think that if the entire disc drive, assembled with a simple click in connection, would be much easier and faster.
