주요 콘텐츠로 건너뛰기
PlayStation 2 Top Cover Replacement
필요한 것
  1. PlayStation 2 Top Cover Replacement, Top Cover: 1 단계, 이미지 1/3 PlayStation 2 Top Cover Replacement, Top Cover: 1 단계, 이미지 2/3 PlayStation 2 Top Cover Replacement, Top Cover: 1 단계, 이미지 3/3
    • Flip the PlayStation 2 over so it lays with the bottom of the device facing upwards.
    • Use the flat edge of a metal spudger to pry the eight flat screw covers out.
    • Remove the following eight screws securing the top cover to the bottom case:
    • Four 55.4 mm Philips screws
    • Four 18.0 mm Phillips screws
  2. PlayStation 2 Top Cover Replacement: 2 단계, 이미지 1/1
    • Some models have a different number of screws and feet. Remove all the feet and screws in the bottom of the case.
    • The 10 screw model has 6 screws in the bottom-most portion and 4 in the upper tray.
  3. PlayStation 2 Top Cover Replacement: 3 단계, 이미지 1/1
    • Peel the warranty sticker (located next to the main power switch) straight away from the case.
    • To avoid activating the VOID that may come up, heat it carefully to remove and replace it clean
  4. PlayStation 2 Top Cover Replacement: 4 단계, 이미지 1/2 PlayStation 2 Top Cover Replacement: 4 단계, 이미지 2/2
    • Flip the PlayStation 2 back to its original upside position.
    • Lift the top cover off the bottom case.
    • To facilitate the removal, it is recommended to pry open the half closer to the power switch first while rocking the top cover towards the front of the bottom case.
    • Carefully remove the power cord that attaches the top and bottom halves by disconnecting the power cord assembly from the top case.
결론
다른 31명이 해당 안내서를 완성하였습니다.
jwyoung
회원 가입일: 11/04/09
2,809 평판
안내서 5개 작성하였습니다
Cal Poly, Team 19-1, Maness Fall 2009 Cal Poly, Team 19-1, Maness Fall 2009 회원
CPSU-MANESS-F09S19G1
4 회원들
안내서 34개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 29
30일 전: 148
전체 시간: 18,326
