주요 콘텐츠로 건너뛰기
PlayStation 3 Hard Drive Replacement
보관된 가이드
해당 안내서는 단지 역사적인 목적으로 보관됩니다. 최신 버전 안내서를 사용하여 수리 하십시오.
필요한 것
  1. PlayStation 3 Hard Drive Replacement, Hard Drive: 1 단계, 이미지 1/1
    • Locate the hard drive bay cover on the side of the PS3.
  2. PlayStation 3 Hard Drive Replacement: 2 단계, 이미지 1/3 PlayStation 3 Hard Drive Replacement: 2 단계, 이미지 2/3 PlayStation 3 Hard Drive Replacement: 2 단계, 이미지 3/3
    • Remove the cover with a spudger.
  3. PlayStation 3 Hard Drive Replacement: 3 단계, 이미지 1/3 PlayStation 3 Hard Drive Replacement: 3 단계, 이미지 2/3 PlayStation 3 Hard Drive Replacement: 3 단계, 이미지 3/3
    • Lift the metal tab on the hard drive enclosure.
    • Pull the tab to slide the hard drive enclosure to the right.
    • Pull the hard drive enclosure out of the PS3.
  4. PlayStation 3 Hard Drive Replacement: 4 단계, 이미지 1/3 PlayStation 3 Hard Drive Replacement: 4 단계, 이미지 2/3 PlayStation 3 Hard Drive Replacement: 4 단계, 이미지 3/3
    • There are four screws on the side of the hard drive enclosure.
    • Two of the screws are shown here. The other two are on the opposite side.
    • The screws are very tight. Be careful not to strip them!
    • Remove the two screws on one side of the hard drive enclosure with a Phillips #1 screwdriver.
    • Flip over the hard drive enclosure and remove the remaining two screws on the other side.
  5. PlayStation 3 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Carefully slide the hard drive out of the metal enclosure.
    • Note the orientation of the hard drive when sliding it out of the enclosure.
결론
다른 4명이 해당 안내서를 완성하였습니다.
iDeleted
회원 가입일: 07/07/10
2,101 평판
안내서 39개 작성하였습니다
댓글 한 개
I dont suppose u can do one for a lughtning zapped power bs upply replace me nt all of my gran turismo amd well all games i play ma6be with a upgrade the speed power and make it ps4 with out the crap of online
Audiophile - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,794
