주요 콘텐츠로 건너뛰기
PlayStation 3 Slim (CECH-300X) Fan system Replacement
필요한 것
동영상 개요
  1. PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: 1 단계, 이미지 1/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: 1 단계, 이미지 2/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement, Fan system: 1 단계, 이미지 3/3
    • Disconnect the fan cable and remove the nine screws from the bottom side.
  2. PlayStation 3 Slim (CECH-300X) Fan system Replacement: 2 단계, 이미지 1/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 2 단계, 이미지 2/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 2 단계, 이미지 3/3
    • Remove the two heat sink clamps and bottom shield, then gently separate the motherboard off the top shield.
  3. PlayStation 3 Slim (CECH-300X) Fan system Replacement: 3 단계, 이미지 1/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 3 단계, 이미지 2/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 3 단계, 이미지 3/3
    • Remove the four Phillips screws and lift the top shield.
  4. PlayStation 3 Slim (CECH-300X) Fan system Replacement: 4 단계, 이미지 1/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 4 단계, 이미지 2/3 PlayStation 3 Slim (CECH-300X) Fan system Replacement: 4 단계, 이미지 3/3
    • That's all.
결론
다른 10명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,368 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,468개 작성하였습니다
댓글 2개
Awesome guide. Thank you so much. I did it, but now I just wonder what that white stuff was when I removed the motherboard. I think it's that thermal stuff people have been talking about and I suppose I have to replace that. I also hope that it's the fan that is what's causing my PS3 to say that it's overheating and shut off. I'm so glad you guys posted this. Great job. I rather do it myself than pay Sony an arm and a leg. Cheers!
chetacheez - 답글
This is CPU / GPU thermal paste / compound. I recommend you Arctic MX-2, MX-4. It is very good and not expensive.
ZFix -
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 40
30일 전: 231
전체 시간: 16,581
