소개
You can use this method if you can't eject the stuck disk by the eject button and the eject hole. The PS3 slim on this video is model CECH-300X.
Full video you can see here:
More info about disassembling, you can find in PlayStation 3 Slim Teardown
부품
지정된 부품이 없습니다.
동영상 개요
Disconnect all cables. You have 4x Torx T8 screws and 7x Phillips screws. Now you can remove outer case.
다른 15명이 해당 안내서를 완성하였습니다.
