주요 콘텐츠로 건너뛰기
PlayStation 3 Slim AC Inlet Replacement
필요한 것
  1. PlayStation 3 Slim AC Inlet Replacement, Top Cover: 1 단계, 이미지 1/1
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. PlayStation 3 Slim AC Inlet Replacement: 2 단계, 이미지 1/2 PlayStation 3 Slim AC Inlet Replacement: 2 단계, 이미지 2/2
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. PlayStation 3 Slim AC Inlet Replacement: 3 단계, 이미지 1/1
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. PlayStation 3 Slim AC Inlet Replacement: 4 단계, 이미지 1/1
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. PlayStation 3 Slim AC Inlet Replacement: 5 단계, 이미지 1/2 PlayStation 3 Slim AC Inlet Replacement: 5 단계, 이미지 2/2
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
  6. PlayStation 3 Slim AC Inlet Replacement, Power Supply: 6 단계, 이미지 1/2 PlayStation 3 Slim AC Inlet Replacement, Power Supply: 6 단계, 이미지 2/2
    • Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
  7. PlayStation 3 Slim AC Inlet Replacement: 7 단계, 이미지 1/1
    • Pull the DC-Out cables straight up to lift their connector up and out of its socket on the power supply.
  8. PlayStation 3 Slim AC Inlet Replacement: 8 단계, 이미지 1/1
    • Remove the two 7.6 mm Phillips screws securing the power supply to the lower case.
  9. PlayStation 3 Slim AC Inlet Replacement: 9 단계, 이미지 1/1
    • Lift the power supply upward from its left edge as viewed from the front of the PS3.
  10. PlayStation 3 Slim AC Inlet Replacement: 10 단계, 이미지 1/2 PlayStation 3 Slim AC Inlet Replacement: 10 단계, 이미지 2/2
    • Continue to lift the left edge of the power supply until it lifts off the two metal posts shown in the second picture.
    • Remove the power supply from the PS3, minding any cables that may get caught.
  11. PlayStation 3 Slim AC Inlet Replacement, AC Inlet: 11 단계, 이미지 1/2 PlayStation 3 Slim AC Inlet Replacement, AC Inlet: 11 단계, 이미지 2/2
    • Lift the AC inlet cables straight upward to remove the AC inlet from the lower case.
결론
다른 25명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
586,305 평판
안내서 619개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 7
7일 전: 26
30일 전: 115
전체 시간: 25,175
