소개
Use this guide to replace the control board. Replacing the control board will provide a new mirror panel, power button, and eject button.
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Use the tip of a spudger to pry the control board out of its housing within the lower case.
Pull the control board ribbon cable away from its socket on the control board.
다른 16명이 해당 안내서를 완성하였습니다.
댓글 2개
I have a PS3 slim that won't turn on, unfortunately my Power/eject button and ribbon cable are completely removed from my PS3. Can I turn it on without the button/ribbon cable?
I replaced the entire psu but without a standby light I have no idea if I'm close to powering it on. I suppose I could get a multimeter but I don't know what I'm testing. Any info would be appreciated.
