주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PlayStation 3 Slim Hard Drive Replacement
필요한 것
  1. PlayStation 3 Slim Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 1개 PlayStation 3 Slim Hard Drive Replacement, Hard Drive: 1 단계, 이미지 2개 중 2개
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  2. PlayStation 3 Slim Hard Drive Replacement: 2 단계, 이미지 1개 중 1개
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  3. PlayStation 3 Slim Hard Drive Replacement: 3 단계, 이미지 2개 중 1개 PlayStation 3 Slim Hard Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Using its attached metal handle, pull the hard drive out of its bay.
    • This is a SATA 2.5" Hard Drive. It can be swapped to another HDD or to a SSD, just make sure it meets these two specs.
  4. PlayStation 3 Slim Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1개 중 1개
    • Remove the four 4.3 mm Phillips screws securing the hard drive to its tray.
  5. PlayStation 3 Slim Hard Drive Replacement: 5 단계, 이미지 2개 중 1개 PlayStation 3 Slim Hard Drive Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the hard drive from its tray.
결론
다른 235명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Andrew Bookholt
599,531 평판
안내서 619개를 작성함
20가이드 댓글
would it be possible to replace it with an ssd?
Cian - 답글 공유
Yes. Done it already.
joachimmoeller - 공유
Yes, but do not expect huge performance improvements, especially if you run games from a physical format (i.e. Blu-ray disc).
João Pedro Almeida - 공유
You definitely can. That will give you less heat to deal with, less noise and vibrations... But the speed gain will probably not be that significant as the PS3 is limited to SATA 1 if I recall correctly...
Replacing it with a 7200 RPM HDD would be more worth it on the price/quality ratio, as 2.5" 500 GB HDD are pretty cheap nowadays.
Théo Crmz - 공유
Can you please tell me playstation 3 super slim model cech-4304a wich type of single lens got? I want to change it and it does not write something like kem or kes..
Tom kan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 37
지난 7일: 308
지난 30일: 1,495
전체 시간: 387,668
