주요 콘텐츠로 건너뛰기
PlayStation 3 Slim Laser lens Replacement
필요한 것
동영상 개요
  1. PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: 1 단계, 이미지 1/2 PlayStation 3 Slim Laser lens Replacement, Blu-ray Disc Drive: 1 단계, 이미지 2/2
    • If present, remove the pieces of tape securing the cables to the body of the Blu-ray drive.
  2. PlayStation 3 Slim Laser lens Replacement: 2 단계, 이미지 1/1
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Blu-ray ribbon cable socket.
    • Be sure you are prying up on the movable retaining flap, not the socket itself.
  3. PlayStation 3 Slim Laser lens Replacement: 3 단계, 이미지 1/1
    • Pull the Blu-ray ribbon cable straight up and out of its socket.
  4. PlayStation 3 Slim Laser lens Replacement: 4 단계, 이미지 1/1
    • Pull the Blu-ray power cable straight up to lift its connector out of the socket on the Blu-ray drive.
  5. PlayStation 3 Slim Laser lens Replacement: 5 단계, 이미지 1/1
    • Remove the single 9.5 mm Phillips screw securing the Blu-ray drive to the lower case.
  6. PlayStation 3 Slim Laser lens Replacement: 6 단계, 이미지 1/2 PlayStation 3 Slim Laser lens Replacement: 6 단계, 이미지 2/2
    • Lift the Blu-ray drive slightly by its right edge to dislodge the control board from its housing.
    • Remove the Blu-ray drive from the PS3.
    • After you reinstall the Blu-ray drive, be sure the control board is firmly seated in the lower case before proceeding.
    • If replacing the Blu-ray drive with a new drive, swap the circuit board from your old drive into the new drive.
결론
다른 20명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,278 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,528개 작성하였습니다
댓글 5개
Donde puedo comprar refacciones y partes para PS3 Slim?
David - 답글
yo vendo amigo = ivaramso@gmail.com para ventas
Ivan Ramirez -
How can this be easy, but the Blu-Ray drive be considered Moderate? You need to complete the Blu-Ray drive removal prior to replacing the laser lens, which means this is at best a Moderate task.
Ben Kevan - 답글
This is not lens replacement, this is drive replacement. Is there a separate guide for lens replacement?
cmchallam - 답글
Shows how to do the laser assembly in the video but not how to reinstall it in the drive. Lazy guide. Just buy a whole new drive if you are following this guide.
Beninja - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 27
30일 전: 106
전체 시간: 32,619
