주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. Pull the AC-In cables upward to remove the AC inlet from the lower case.
    • Pull the AC-In cables upward to remove the AC inlet from the lower case.
  2. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard. Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the motherboard.
  3. Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Pull the control board ribbon cable up and out of its socket on the motherboard.
    • Remove the control board.
  4. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Use the flat edge of a metal spudger to pop up the small access door on the bottom cover near the front of the PS3.
    • Remove the blue Phillips screw hidden under the access door.
  5. Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
    • Slide the hard drive bay cover toward the right side of the lower case, then pull it away from the front edge to remove it from the PS3.
  6. Using its attached metal handle, pull the hard drive out of its bay.
    • Using its attached metal handle, pull the hard drive out of its bay.
  7. Remove the following five screws securing the motherboard assembly to the lower case:
    • Remove the following five screws securing the motherboard assembly to the lower case:
    • Two silver 6 mm Phillips
    • Three black 8 mm Phillips
  8. Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Lift the motherboard assembly from its front edge and remove it from the lower case, minding the antenna cable still attached to the lower case.
    • Be careful not to bend the metal antenna bodies as you lift the motherboard assembly.
결론
Andrew Bookholt
563,215 평판
안내서 618개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,147
