Introduction
Use this guide to replace your PlayStation 3 Slim's CR 2032 coin-cell PRAM battery.
Turn the PS3 over and lay it on its backside.
Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
Squeeze the AC inlet connector's locking mechanism and pull straight up to disconnect it from the power supply.
While holding the plastic retainer down against the board, use the tip of a spudger to pry the PRAM battery out of its housing.
20 other people completed this guide.
8 Comments
ATTENTION: This guide is not valid for PS3 slim CECH-3004B!
from the number 11 you notice that your ps3 is different.
The CECH-3004B version does not give direct access to the 2032 battery.
You must also disassemble the motherboard from the grid (and all the pieces that obstruct this operation)
It is possible but it is more difficult
I found this to be the case too. Did you end up replacing the battery? If so, how did you do it?
It is kind of hard to tell by the photo alone: The plus (flat) side of the battery must face up when you insert it.
kuhnbn hob - 답글
hey i need serious help i opened my super slim to replace the battery and could not figure how to get it out thought off lifting the socket might allow me to replace the battey much to my horror now socket is torn from the motherborad my console is stuck in black screen and a day before i tried to update from safe mode still a black screen now if i turn on the console i know its waiting for to confirm update iniatlization can i update the console without cmos battery or shomhow cancel it and be able to boot into recovery again
Hello, I need help haha I wanted to remove the battery and effectively broke the plastic and released the solder that goes from the battery to the motherboard, can I solder it again?
