주요 콘텐츠로 건너뛰기
소개
Use this guide to remove the plastic top cover.
  1. Turn the PS3 over and lay it on its backside.
    • Turn the PS3 over and lay it on its backside.
    • Carefully peel the warranty sticker up off the lower case to reveal a hidden screw cover.
    • To avoid activating the VOID that may come up, heat the sticker carefully to remove and replace it cleanly.
  2. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case. Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
    • Use the flat end of a metal spudger to pry up the seven screw covers around the edge of the lower case.
  3. Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
    • Remove the seven 37 mm Phillips screws securing the top cover to the lower case.
  4. Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
    • Remove the four 13.3 mm T8 security Torx screws beneath the Blu-ray drive opening. (Some models may only have three screws)
  5. Lift the top cover from its rear edge and rotate it toward the front of the PS3. Lift the top cover off the PS3.
    • Lift the top cover from its rear edge and rotate it toward the front of the PS3.
    • Lift the top cover off the PS3.
결론
다른 84명이 해당 안내서를 완성하였습니다.
Andrew Bookholt
561,341 평판
안내서 618개 작성하였습니다
No good mine a Sony.
james register - 답글
Thank you this helped me so much!!!!
Megan Davis - 답글
댓글 쓰기
조회 통계:
24 시간 전: 10
7일 전: 88
30일 전: 328
전체 시간: 61,296
