주요 콘텐츠로 건너뛰기
부품
지정된 부품이 없습니다.
  1. PlayStation 3 Slim Top Shield Assembly Replacement, Top Shield Assembly: 1 단계, 이미지 1/1
    • Disconnect the DC-In and Blu-ray power cables from the motherboard.
    • Pull the cables straight upward to lift the connectors up and out of their sockets on the motherboard.
  2. PlayStation 3 Slim Top Shield Assembly Replacement: 2 단계, 이미지 1/1
    • Pull the fan cables straight up to lift the fan connector up and out of its socket on the motherboard.
  3. PlayStation 3 Slim Top Shield Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the following nine screws holding the motherboard assembly together:
    • Four 14.8 mm shouldered Phillips
    • Five 9.5 mm Phillips
  4. PlayStation 3 Slim Top Shield Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the two heat sink clamps from the bottom of the motherboard assembly.
  5. PlayStation 3 Slim Top Shield Assembly Replacement: 5 단계, 이미지 1/1
    • If necessary, gently pry the motherboard off the top shield near the heat sink and its shroud.
  6. PlayStation 3 Slim Top Shield Assembly Replacement: 6 단계, 이미지 1/2 PlayStation 3 Slim Top Shield Assembly Replacement: 6 단계, 이미지 2/2
    • Gently press the board away from the top shield assembly near the fan connector and the corner of the board near the wireless sockets.
  7. PlayStation 3 Slim Top Shield Assembly Replacement: 7 단계, 이미지 1/1
    • Lift the top shield assembly off the motherboard from its front edge.
    • Be careful not to damage the sockets as you rotate the top shield assembly away from the motherboard.
결론
Andrew Bookholt
572,310 평판
안내서 618개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,730
