소개
Use this guide to replace your PlayStation 3's smart plate.
필요한 것
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the single 8.5 mm T10 Security Torx screw from the smart plate.
How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Pull the smart plate toward the hard drive bay, then lift it off the body of the PS3.
different in mine too, Model: CECHP01
mine does not have one at all
1How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Did not find in my CECHH01
I don’t have this bracket, where I can get it ?
Paul Bidny - 답글
다른 32명이 해당 안내서를 완성하였습니다.
댓글 한 개
Finde ich total einfach, sogar das tauschen der Wärmeleidpaste muss ich sagen. Leichter als bei der XBOX 360 aufjedenfall. Klar ich habe bestimmt schon 6-7 FatLady auseinander genommen und diese mit Frischer Wärmeleidpaste versorgt.
Fake repair. Real fault: How to Delid and fix the Yellow Light of Death for good (NEC TOKIN Replacement) https://gbatemp.net/threads/how-to-delid...
Player - 답글
