주요 콘텐츠로 건너뛰기
PlayStation 3 Super Slim Laser Unit Replacement
필요한 것
동영상 개요
  1. PlayStation 3 Super Slim Laser Unit Replacement, Laser Unit / Deck  replacement: 1 단계, 이미지 1/1
    • Turn off the console and disconnect all cables.
  2. PlayStation 3 Super Slim Laser Unit Replacement: 2 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 2 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 2 단계, 이미지 3/3
    • You must remove the warranty sticker and 4 screws.
  3. PlayStation 3 Super Slim Laser Unit Replacement: 3 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 3 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 3 단계, 이미지 3/3
    • After removing HDD bay cover, you will see another 3 screw.
  4. PlayStation 3 Super Slim Laser Unit Replacement: 4 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 4 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 4 단계, 이미지 3/3
    • Push there to release and remove upper back bezel.
  5. PlayStation 3 Super Slim Laser Unit Replacement: 5 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 5 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 5 단계, 이미지 3/3
    • The upper front bezel is harder to remove.
  6. PlayStation 3 Super Slim Laser Unit Replacement: 6 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 6 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 6 단계, 이미지 3/3
    • Remove 7 screws to release top cover.
  7. PlayStation 3 Super Slim Laser Unit Replacement: 7 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 7 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 7 단계, 이미지 3/3
    • Disconnect two flex-cables and move the Laser Unit. Remove the two screws and the small cable and then take out the Power Supply Unit.
  8. PlayStation 3 Super Slim Laser Unit Replacement: 8 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 8 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 8 단계, 이미지 3/3
    • To release the laser unit disconnect this flex-cable.
    How is called this flex cable? Mine is broken so I have to buy another
    Gianpaolo Scionti - 답글
  9. PlayStation 3 Super Slim Laser Unit Replacement: 9 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 9 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 9 단계, 이미지 3/3
    • One flex-cable, for rubbers and the metal bezel.
  10. PlayStation 3 Super Slim Laser Unit Replacement: 10 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 10 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 10 단계, 이미지 3/3
    • Disconnect this flex-cable and attach it to the new spare part. Let's start assembling.
  11. PlayStation 3 Super Slim Laser Unit Replacement: 11 단계, 이미지 1/3 PlayStation 3 Super Slim Laser Unit Replacement: 11 단계, 이미지 2/3 PlayStation 3 Super Slim Laser Unit Replacement: 11 단계, 이미지 3/3
    • Assembling, assembling...
  12. PlayStation 3 Super Slim Laser Unit Replacement: 12 단계, 이미지 1/2 PlayStation 3 Super Slim Laser Unit Replacement: 12 단계, 이미지 2/2
    • Let's test the device before fully assembling it.
결론
다른 10명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,341 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
322 회원들
안내서 2,541개 작성하였습니다
댓글 5개
Very good job, kudos!
Kevin Borras - 답글
I have found that there are to types of lasers do you sell the second one that does not have the black screws on top but are silver. I have found the one with the silver screws has a smaller laser flex cable and plug. its for the cech-43xx
jack blevinski - 답글
My only problem now is how to purchase the right Laser unit? Any specs for the right Laser unit? Thanks
Sebasttain Tuscano - 답글
I’ve done this but my ps3 still doesn’t read disks it spins it up 4 odd times but doesn’t read them and it sounds like the disk skims the top of the laser unit but it hasn't done any damage and it does it with both units, I’m so lost on what to do.
Dome Bucket - 답글
I am replacing the optical drive in my console. But didn't note where the drive ribbon was positioned!? Every video I have found, they just pop right in...my original and replacement drives, have larger receptacles than the ribbon it self. There are at least 5 pins, that don't have (potentially) anything connecting them, to the ribbon. I don't want to randomly place the ribbon in one of the possible (7?) positions and fry something in the process...so where do I connect the smaller ribbon?!
Robert Shelton - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 38
30일 전: 103
전체 시간: 23,797
